VARE gives you full control over plugin versions in Obsidian. With a simple UI, you can install any version of Community Plugins - whether it’s an older version or even a beta.
Who is it for?
Plugin Developers: Test you plugin across multiple versions without hassle.
Plugin Testers: Roll back instantly to reproduce bugs or compare behaviors.
User: Prefer a previous version because the latest update broke something or an older version was just better?
Why use it?
Stay inside Obsidian - no manual file fiddling.
See all available versions for each plugin.
Switch versions quickly with just a couple of clicks.
No manual setup required - installed community plugins automatically get detected.
Yes, it is definitely inspired by BRAT but I doesn’t like that you have to manually add the versions you would like to install in BRAT. In my plugin the versions get automatically fetched from GitHub and you simply select the version you want from the drop down.
