Hello
I absolutly Nuby but I try make simple plugin for URI decode for selected text
I take for template “url-into-selection” and rewrite it for mi goal
It don`t worked - “faled to lad plugin”
var obsidian = require('obsidian');
var electron = require('electron');
/* global Reflect, Promise */
var extendStatics = function(d, b) {
extendStatics = Object.setPrototypeOf ||
({ __proto__: [] } instanceof Array && function (d, b) { d.__proto__ = b; }) ||
function (d, b) { for (var p in b) if (Object.prototype.hasOwnProperty.call(b, p)) d[p] = b[p]; };
return extendStatics(d, b);
function __extends(d, b) {
function __() { this.constructor = d; }
d.prototype = b === null ? Object.create(b) : (__.prototype = b.prototype, new __());
function __awaiter(thisArg, _arguments, P, generator) {
function adopt(value) { return value instanceof P ? value : new P(function (resolve) { resolve(value); }); }
return new (P || (P = Promise))(function (resolve, reject) {
function fulfilled(value) { try { step(generator.next(value)); } catch (e) { reject(e); } }
function rejected(value) { try { step(generator["throw"](value)); } catch (e) { reject(e); } }
function step(result) { result.done ? resolve(result.value) : adopt(result.value).then(fulfilled, rejected); }
step((generator = generator.apply(thisArg, _arguments || [])).next());
function __generator(thisArg, body) {
var _ = { label: 0, sent: function() { if (t[0] & 1) throw t[1]; return t[1]; }, trys: [], ops: [] }, f, y, t, g;
return g = { next: verb(0), "throw": verb(1), "return": verb(2) }, typeof Symbol === "function" && (g[Symbol.iterator] = function() { return this; }), g;
function verb(n) { return function (v) { return step([n, v]); }; }
function step(op) {
if (f) throw new TypeError("Generator is already executing.");
while (_) try {
if (f = 1, y && (t = op[0] & 2 ? y["return"] : op[0] ? y["throw"] || ((t = y["return"]) && t.call(y), 0) : y.next) && !(t = t.call(y, op[1])).done) return t;
if (y = 0, t) op = [op[0] & 2, t.value];
switch (op[0]) {
case 0: case 1: t = op; break;
case 4: _.label++; return { value: op[1], done: false };
case 5: _.label++; y = op[1]; op = [0]; continue;
case 7: op = _.ops.pop(); _.trys.pop(); continue;
default:
if (!(t = _.trys, t = t.length > 0 && t[t.length - 1]) && (op[0] === 6 || op[0] === 2)) { _ = 0; continue; }
if (op[0] === 3 && (!t || (op[1] > t[0] && op[1] < t[3]))) { _.label = op[1]; break; }
if (op[0] === 6 && _.label < t[1]) { _.label = t[1]; t = op; break; }
if (t && _.label < t[2]) { _.label = t[2]; _.ops.push(op); break; }
if (t[2]) _.ops.pop();
op = body.call(thisArg, _);
} catch (e) { op = [6, e]; y = 0; } finally { f = t = 0; }
if (op[0] & 5) throw op[1]; return { value: op[0] ? op[1] : void 0, done: true };
var URIdecode = /** @class */ (function (_super) {
__extends(URIdecode, _super);
function URIdecode() {
return _super !== null && _super.apply(this, arguments) || this;
URIdecode.prototype.onload = function () {
return __awaiter(this, void 0, void 0, function () {
var _this = this;
return __generator(this, function (_a) {
this.addCommand({
callback: function () { return _this.URIdecode(); },
hotkeys: [
modifiers: ["Mod", "Shift"],
key: "d",
return [2 /*return*/];
URIdecode.prototype.URIdecode = function () {
var editor = this.getEditor();
var selectedText = URIdecode.getSelectedText(editor);
editor.replaceSelection(encodeURI(selectedText));
return URIdecode;
}(obsidian.Plugin));
module.exports = URIdecode;
All realy function is:
Maybe anybody can help? Where is my mistake?
It zip my try: source for my try
