Plugin to disable Web Viewer OR prevent settings changes
the problem
I use an app called Cold Turkey Blocker Pro to regulate my internet use. (excellent app. better than Freedom IMO, though, unlike Freedom, only available on macOS.) with Obsidian, I can circumvent the block whenever I like.
solutions?
  • delete Obsidian. (difficult, since I find it so useful and have hundreds of notes scattered across a number of vaults.)
  • a plugin to block Web Viewer: none exists, AFAIK.
  • a plugin to block me from changing settings generally, for a while. again, this doesn’t exist yet, AFAIK.
