Disclaimer
Is this plugin completely free? Yes — the plugin is MIT licensed. Provider subscriptions or API usage may have separate costs.
Is this plugin vibe-coded beyond the author’s ability to comprehend how it works? Yes
Community Directory:https://community.obsidian.md/plugins/oh-my-claudian
Oh My Claudian: coding agents in your Obsidian vault
Hi everyone! I’m the developer of Oh My Claudian, an Obsidian plugin for working with coding agents right inside your vault.
If you already use a coding agent, Oh My Claudian gives you a sidebar chat and inline-edit workflow connected to your notes. You can bring vault files into a conversation with @ mentions or attachments, then review suggested note changes in a word-level diff preview before applying them.
It supports Claude Code, Codex, Cursor Agent, Grok, Oh My Pi, OpenCode, and Pi. Each provider keeps its own supported models, permissions, and controls, so the interface doesn’t pretend every agent works the same way.
A few things you can do:
- Keep multiple conversations open, and resume or fork sessions.
- Edit selected note text with a preview before applying changes.
- Use slash commands, skills, file references, and file or folder attachments.
- Check provider CLI readiness and manage supported installs or updates from settings. Commands are shown for confirmation before they run.
Oh My Claudian is local-first and sends no plugin telemetry. Prompts and attached context are sent to the provider you choose, under that provider’s terms and account setup. The plugin is desktop-only and requires at least one supported provider CLI; provider usage may require a subscription or API billing.
You can find it in Settings → Community plugins → Browse by searching for “Oh My Claudian,” or view its https://community.obsidian.md/plugins/oh-my-claudian.
I’ll keep future updates in this thread. Thanks for taking a look!
