A freshly released Obsidian plugin — mindelixir-mindmap: SSShooter/obsidian-mindmap
It ships with two core features:
View any Markdown file as an interactive mind map
Embed mind maps directly inside a Markdown document
Markdown → Mind Map
Mindelixir-mindmap converts a Markdown file into a mind map by reading the hierarchy of headings and lists.
Mind Elixir Plaintext
Mind Elixir Plaintext is a format similar to Markdown nested lists, extended with syntax for connections, summary nodes, and styling.
Using simple indentation, ID references, and JSON-like inline declarations, you can build complex mind map structures entirely in plain text — and the format is also very AI-friendly.
- Product Development
- Research [^research]
- User Interviews {"color": "#3298db"}
- Competitor Analysis {"color": "#3298db"}
- }:2 Research Summary
- Development [^dev]
- Architecture Design {"color": "#2ecc71"}
- Frontend/Backend Integration {"color": "#f39c12"}
- } Dev Summary
- > [^research] >-leads to-> [^dev]
Mind Elixir Plaintext can also be embedded as a code block inside existing articles. Here’s how it looks on mobile:
With regular Markdown you can only update the mind map by editing the text. For Mind Elixir Plaintext files, a two-way sync feature (editing the mind map updates the source text in real time) is currently in development.
Mindelixir-mindmap is under active development. If you run into any issues or have ideas for new features, feel free to open an Issue or PR on GitHub ![]()
