Hello
I absolutly Nuby but I try make simple plugin for URI decode for selected text
I take for template “url-into-selection” and rewrite it for mi goal
It don`t worked - “faled to lad plugin” :sneezing_face:
var obsidian = require('obsidian');
var electron = require('electron');
/* global Reflect, Promise */
var extendStatics = function(d, b) {
    extendStatics = Object.setPrototypeOf ||
        ({ __proto__: [] } instanceof Array && function (d, b) { d.__proto__ = b; }) ||
        function (d, b) { for (var p in b) if (Object.prototype.hasOwnProperty.call(b, p)) d[p] = b[p]; };
    return extendStatics(d, b);
function __extends(d, b) {
    function __() { this.constructor = d; }
    d.prototype = b === null ? Object.create(b) : (__.prototype = b.prototype, new __());
function __awaiter(thisArg, _arguments, P, generator) {
    function adopt(value) { return value instanceof P ? value : new P(function (resolve) { resolve(value); }); }
    return new (P || (P = Promise))(function (resolve, reject) {
        function fulfilled(value) { try { step(generator.next(value)); } catch (e) { reject(e); } }
        function rejected(value) { try { step(generator["throw"](value)); } catch (e) { reject(e); } }
        function step(result) { result.done ? resolve(result.value) : adopt(result.value).then(fulfilled, rejected); }
        step((generator = generator.apply(thisArg, _arguments || [])).next());
function __generator(thisArg, body) {
    var _ = { label: 0, sent: function() { if (t[0] & 1) throw t[1]; return t[1]; }, trys: [], ops: [] }, f, y, t, g;
    return g = { next: verb(0), "throw": verb(1), "return": verb(2) }, typeof Symbol === "function" && (g[Symbol.iterator] = function() { return this; }), g;
    function verb(n) { return function (v) { return step([n, v]); }; }
    function step(op) {
        if (f) throw new TypeError("Generator is already executing.");
        while (_) try {
            if (f = 1, y && (t = op[0] & 2 ? y["return"] : op[0] ? y["throw"] || ((t = y["return"]) && t.call(y), 0) : y.next) && !(t = t.call(y, op[1])).done) return t;
            if (y = 0, t) op = [op[0] & 2, t.value];
            switch (op[0]) {
                case 0: case 1: t = op; break;
                case 4: _.label++; return { value: op[1], done: false };
                case 5: _.label++; y = op[1]; op = [0]; continue;
                case 7: op = _.ops.pop(); _.trys.pop(); continue;
                default:
                    if (!(t = _.trys, t = t.length > 0 && t[t.length - 1]) && (op[0] === 6 || op[0] === 2)) { _ = 0; continue; }
                    if (op[0] === 3 && (!t || (op[1] > t[0] && op[1] < t[3]))) { _.label = op[1]; break; }
                    if (op[0] === 6 && _.label < t[1]) { _.label = t[1]; t = op; break; }
                    if (t && _.label < t[2]) { _.label = t[2]; _.ops.push(op); break; }
                    if (t[2]) _.ops.pop();
            op = body.call(thisArg, _);
        } catch (e) { op = [6, e]; y = 0; } finally { f = t = 0; }
        if (op[0] & 5) throw op[1]; return { value: op[0] ? op[1] : void 0, done: true };
var URIdecode = /** @class */ (function (_super) {
    __extends(URIdecode, _super);
    function URIdecode() {
        return _super !== null && _super.apply(this, arguments) || this;
    URIdecode.prototype.onload = function () {
        return __awaiter(this, void 0, void 0, function () {
            var _this = this;
            return __generator(this, function (_a) {
                this.addCommand({
                    callback: function () { return _this.URIdecode(); },
                    hotkeys: [
                            modifiers: ["Mod", "Shift"],
                            key: "d",
                return [2 /*return*/];
    URIdecode.prototype.URIdecode = function () {
        var editor = this.getEditor();
        var selectedText = URIdecode.getSelectedText(editor);
            editor.replaceSelection(encodeURI(selectedText));
    return URIdecode;
}(obsidian.Plugin));
module.exports = URIdecode;
All really function is:
Maybe anybody can help? Where is my mistake?
It zip my try: source for my try
