Plugin: Floating Settings – open your Obsidian Settings in a separate window
Hey everyone! :waving_hand:
I just published a plugin that I’ve personally wanted for a long time:
:gear: Floating Settings Plugin
This plugin lets you open Obsidian’s Settings panel in a fully separate popout window. Perfect for people with multiple monitors or who want to adjust settings without covering their workspace.
:white_check_mark: Features
  • Opens the default settings panel in a dedicated external window
  • Applies custom styling (full width & height, no background dimming)
  • Automatically removes the modal on close to avoid illegal access errors
  • Super lightweight – does one thing well
:package: Installation
Manually install by downloading the latest release from GitHub:
github .com/wambo121/Floating-Settings-for-Obsidian/tree/main
Unzip into .obsidian/plugins/floating-settings/ and enable it under Community Plugins
:laptop: Screenshot
Obsidian_UKbaXPNr65
:hot_beverage: Support
If you enjoy this plugin, feel free to support me here:
buymeacoffee .com/morganfrey
Or give the repo a :star: on GitHub:
Do you plan for this plugin to either be a published community plugin or at least accessible through BRAT?
I’ve also seen the need for something like this, but I don’t want to start messing with such a manual installation (and update) procedure.
And does it allow for full editing in the main window, or not?
I have been using the Floating Settings plugin with the same name in the plugin library, and this plugin relies on another Floating plugin, which has become invalid after recent updates. Looking forward to your plugin being listed on BRAT or official plugin platforms
The plugin is currently undergoing the manual review process for publication in the official Obsidian store. I’m not familiar with BRAT yet, but I’ll check it out and see if it makes sense to release it there as well.
Yes, the main window remains fully editable and usable—that was precisely the main idea behind this plugin. For example, it allows you to quickly test theme changes and see how they look across different files.
My plugin doesn’t rely on external dependencies, so it should remain stable going forward. As mentioned earlier, it’s currently in the manual review stage for official listing. I’ll also look into BRAT to provide an alternative method of installation soon.
Great news – the plugin is available through BRAT!
If you’d like to try it out, just add the following GitHub repo to BRAT:
Magic. I’ve always wanted settings to open in a tab or new window! Hope to see this in the official store too.
Magical. I’ve used Obsidian for YEARS and have never understood why the settings page takes over the whole interface and leaves us having to open/close as we tweak.
Today, you are my internet hero!
Any idea when it will be added to the Community Plugins directly?
THIS exactly. Inconceivable.
Pretty useful to create a File Recovery window instance on the right and lookup+restore one by one like crazy cause we don’t we have bulk restore.
