Hi everyone! ![]()
I’m happy to share a plugin I’ve been using daily: Auto Note Importer.
If you ever wished you could automatically turn Airtable data into clean, structured Markdown notes inside your vault—this plugin does just that.
I got tired of copy-pasting my research summaries and project logs from Airtable into Obsidian. So I built a tool that does it for me (and hopefully now for you too!).
Quick Demo
Check out this short demo showing how it works:
Key Features
Airtable Integration
Connect directly via your Personal Access Token and select a base/table. -
Custom Templates
Use any.mdfile with{{fieldName}}placeholders. Supports dot notation like{{Attachment.0.url}},{{User.name}}, and more. -
Organized Output
Specify folders, filenames (from any field), and let the plugin auto-create missing directories. -
Manual & Auto Sync
Sync on demand or at a regular interval. -
Duplicate Note Handling
Specify a “primary field” to avoid creating the same note twice. Existing notes will be skipped or updated depending on your settings. -
No coding required
All setup is done through the plugin settings panel — just a few clicks.
Use Case
- Save and organize YouTube summaries or research content from Airtable into Obsidian automatically
Planned
Currently Airtable-only, but more database sources (e.g. Notion, Supabase, custom APIs) are on the roadmap.
Installation
Install via BRAT or clone from GitHub:
Full instructions, example templates, and a quick setup demo are in the README.
If you give it a try, I’d love to hear your feedback — ideas, bug reports, or feature requests are all welcome ![]()
Thanks for reading!
