Please add block system from notion, it would be much easier to manage content
the ability to manipulate blocks like the way you can in notion
  • drag large pieces of indented text
  • or like the way toggle notes work
  • being able to move everything indented under a specific paragraph/text/bullet
  • etc
it doesn’t have to “block reference” or however notion does it
but having the ability to control large pieces of content would be lovely
(i know this has been brought up already, but this feature is the only reason i use notion sometimes)
and also the ability to select everything under a “toggle”
Can’t agree more, I’m looking for ways to '“move sections” without having to
  1. create temporal headings (to then drag with the outline. And may it never be subheadings carried by accident in that process because it gets messy) or
  2. select lines manually (a pain on mobile)
Hope [New Plugin] Dragger helps with this process.
This is a duplicate of
and
