Hello guys!
I want to ask you. Is there a plagin for drawing in obsidian like in one note (ability to draw in a separate page)? I will really appreciate your help.
Handwritten notes are not what Obsidian is very good at, but there are some plugins you might want to take a look at.
These plugins create drawing panes inside Obsidian:
- GitHub - zsviczian/obsidian-excalidraw-plugin: A plugin to edit and view Excalidraw drawings in Obsidian
- GitHub - juliusgb/obsidian-tldraw-plugin: A plugin to edit and view TLdraw drawings in Obsidian
Another approach is relying on an external PDF drawing tool, which this plugin adopts:
Personally, I don’t use these tools for handwriting purposes. I only type in Obsidian, and I use GoodNotes whenever I need handwriting and then I export PDFs from GoodNotes to Google Drive. I can access these PDFs from Obsidian because I put a symbolic link to the backup folder in my vault.
Thank you, really appreciate it
