When storing a command or another piece of code that contains a pipe character within a table, it appears to not be fully escaped.
Create a table → |Something|Something|
insert a piece of “code block” that contains a pipe character as the left side or right-side of the two column table. For example here is a Bash code block with multiple pipes.
for ext in $(echo ".xls .xls* .xltx .csv .od* .doc .doc* .pdf .pot .pot* .pp*");do echo -e "\nFile extension: " $ext; find / -name *$ext 2>/dev/null | grep -v "lib|fonts|share|core" ;done
Put another you want on the other side of the table, fully completing the table requirements. Then once moving into the next row, the table will display but its messed up. See attacked images pip-test-1, and pipe-test-2
You can fix this by using the escape characters on the pipes. This works to stop the table-attempting to finish a cell. This shows that the behaviors are not fully escaped, as the escape character shows up as itself in the code block, but still works to break the pipe’s effect. See image pipe-test-3. The code block looks like this after escaping all the pipes:
for ext in ${echo ".xls .xls* .xltx .csv .od* .doc .doc* .pdf .pot .pot* .pp*");do echo -e "\nFile extension: " $ext; find / -name *$ext 2>/dev/null \| grep -v "lib\|fonts\|share\|core" ;done
The desired result is that when pipe characters are within a code-block, there effects are fully escaped. So I can make respective tables with commands | definitions.
Have to escape the pipe characters, then the commands look odd, because they now also show the escape characters before the pipes…ie ( | ). Visually this is ugly, and can be confusing if these notes are going to a different user than the one writing them.
Obsidian version: v1.1.9
Installer version: v1.0.3
Operating system: Windows 10 Home 10.0.22621
Legacy editor: off
Plugins installed: 0
Plugins enabled: 0
