Permanently removing Vault from Sync menu
Hi all,
Over time I’ve created a bunch of Vaults. I’ve synced these over several devices. No I have deleted all but 1. But I can stell open syync, clivk on one of the vaults that I deleted from all my machines and start using it again, including all its content.
Nioce. But now I want to also permanently remove some vaults from the Obsidian sync-select-a-vault menu.
I can click the “Connect” button. But nothing else that would remove this vault.
How do I remove a vault freom the sync menu?
I’m stupid. It’s not managed from the screen you select the vault in, but from the Sync menu inside of you Obsidian itself.
Problem solved.
