Permalink Problem
Hello all!
I recently discover Obsidian and the amazing plugin Digital Garden Obsidian Plugin .
I tried to put my first note online and it worked.
I’m having problems in publishing more content. Basically I got the following error: obsidian permalink - Pastebin.com .
It is an error with permalinks, apparently it’s creating the same permalink for different notes…I guess. I am working locally with the repository, adding some HTML and, theoretically JS and CSS.
Edit: I deleted and created again my project, but the problem persist.
Can anyone suggest something? I would really appreciate that.
Judging from the log and multiple input files are writing to dist/index.html, multiple files have the property key and value dg-home: true. There can only be one home (AKA index) file.
OMG it was that easy, Thank you!!! I was totally lost, but the solution was just there. Thank you!
