Periodix-Planner: Turn Obsidian into a time-aware planning system
I’ve built an Obsidian plugin that automatically generates tightly interconnected periodic notes (daily → weekly → monthly → quarterly → yearly) that are fully navigable and hierarchy-aware, combined with a time budgeting system that treats time like a finite investment portfolio, where you allocate hours into categories and track where your time actually goes.
GitHub - owner with name (I can’t post links here): Real1tyy/Periodix-Planner
Core Features
Automatic Periodic Note Generation
  • Automatically creates periodic daily, weekly, monthly, quarterly, and yearly notes
  • Notes are intelligently linked through frontmatter for easy navigation
Time Budget System
  • Define your available hours and allocate them across categories (work, learning, health, relationships, etc.)
  • Budgets cascade down the hierarchy: Yearly → Quarterly → Monthly → Weekly → Daily
  • Smart tracking with color-coded indicators (green/yellow/red)
Visual Statistics
  • Pie charts showing category distribution at each time level
  • Detailed tables with allocated vs. remaining hours
  • Progress bars for visual tracking
Interactive Allocation Editor
  • Drag-to-adjust percentage bars
  • Quick-fill buttons (10%, 25%, 50%, Max)
  • Parent budget warnings to prevent over-allocation
  • Undo/redo support
Why I built this
Most planning systems focus on output (“What did I get done?”). This plugin focuses on inputs (“What am I spending my time on?”). It’s not a task manager—it’s a time investment tracker that helps you decide what deserves your time in the first place.
To Find Out More
  • Full YouTube video showing all features in action
  • A lot screenshots in the documentation and README to see how it looks visually
  • Comprehensive documentation with all settings and features documented
  • Everything is linked in the GitHub repo README
I’d love to hear your feedback. Feel free to test it out and let me know your thoughts.
Installation: Available via BRAT (Community Plugins coming soon)
Is this a “vibe coded” or chatbot created plugin?
Depends on how you define it. I used Cursor to speed up the development and have a lot of experience with it.
That’s fine. The queue of plugins to be approved is getting longer and longer because of chatbots doing the work. I’d just mention the chatbot assistance from the start.
