Performance issue with built-in canvas plugin
  • create new vault
  • create canvas
  • add 100 single line text cards
  • pan the canvas
Did you follow the troubleshooting guide? Yes
No significant freezes
Every time some elements are appear/dissapear from the viewport there are noticable freezes. But when all elements are present on the viewport, panning makes no freezes.
Video example
Obsidian version: v1.4.14
Installer version: v1.1.9
Operating system: Windows 10 Home 10.0.19045
Legacy editor: off
AMD Ryzen 5 4600U
Also checked on another machine, with fresh Obsidian install, with the same result:
AMD Ryzen 9 5900x + GeForce RTX 3060 (200 text cards are required to get the same performanse issue)
I’m guessing it is because some internal optimisation takes place when the element dissapears from the viewport, but instead of helping the performance it worsens it
Yes, I know, 100 notes is a big amout, but depending on the machine that kind of problem may appear on 40+ notes, which is a reasonable amount. I expect the performance to be comparable to the graph view, where you can have 1000+ notes with the title shown, without any performance issues.
Thank you for developing Obsidian!
