- Create new Vault
- Install Theme (minimal or AnuPpuccin with catppuccin Frappé for dark mode)
- Systemwide is the theme enabled
- Add .pdf file to the vault
- Open .pdf file in native pdf.viewer
- Enable “Adapt to theme”
- It applies Dark Mode (black background white text) instead of enabled theme catppuccin frappé.
Did you read and follow the Troubleshooting Guide ? [Yes/No]
If a theme is applied to the whole vault, pdf-viewer should apply this as well instead of registering light/dark mode instead of the actual theme, if the button indicates Adapt to theme.
If Adapt to theme gets enabled it should apply the actual theme settings instead of light/dark mode.
Obsidian version: 1.14.4
Installer version: 1.14.4
Operating system: Darwin Kernel Version 27.0.0: Tue Aug 11 21:02:59 PDT 2026; root:xnu-13432.1.9~1/RELEASE_ARM64_T8142 27.0.0
Community theme: AnuPpuccin 1.5.0
Snippets enabled: 1
Plugins installed: 1
Plugins enabled: 1
1: Style Settings v1.0.9
To fix this issue, I am currently adding a custom css script:
.theme-dark.pdf-invert-dark .pdf-viewer-container {
background-color: var(–background-primary);
