Pdf to markdown/note, a way?
Hello community,
Is there a way to transform a pdf to a note/markdown?
Thanksss
You can also try selecting everything in the PDF (Ctrl/Cmd+A should work), copying it, and pasting it into a note. As Siira says, the results will probably be rough.
Ok understand this. Thank you for your return.
And to put a PDF in a Note? Is this possible?
Its so easy on the canva, but dont know if its possible in the note itself.
Pandoc should be able to do a good job of converting PDF to Markdown:
https://pandoc.org/
Ah, nice lol!
Yes thanks
