PDF Export Not Working in RTL (Right-to-Left) Interface Languages
Title:
PDF export fails when Obsidian interface language is set to RTL languages (e.g. Persian or Arabic)
Description:
When the Obsidian interface is switched to a right-to-left language such as Persian (فارسی) or Arabic (العربية), the built-in “Export to PDF” function stops working. Clicking on the export command produces no output and no error message appears in the console.
Steps to Reproduce:
  1. Open Obsidian.
  2. Go to Settings → Appearance → Language, and set it to فارسی or العربية.
  3. Open any note.
  4. Use the built-in command: File → Export to PDF (or use the command palette).
  5. Observe that no PDF file is generated.
Expected Behavior:
The note should be successfully exported to a PDF file, just like when the interface is in English or other LTR languages.
Actual Behavior:
No PDF file is created, and no visible error message appears. Switching the interface back to English restores normal PDF export functionality.
Environment:
  • App Version: (e.g. v1.9.14)
  • OS: (e.g. Windows 10 )
  • Language: Persian (فارسی) or Arabic (العربية)
  • Community Plugins: Disabled (tested in Safe Mode)
Additional Notes:
  • The issue seems related to the directionality or localization of the UI, not to any specific note content.
  • Occurs even with plain text files and in Safe Mode.
  • May involve CSS or internal PDF rendering components not fully supporting RTL UI layouts.
thanks
I can’t reproduce this bug any longer. Let me know if you still expirience it
