PDF and print style reset with code syntax highlighting
  1. Save, for example, as print.css in .obsidian/snippets folder.
  2. Enable the CSS snippet in Settings -> Appearance -> CSS snippets
  3. Export your notes to PDF
Tested with default dark theme on 2022-02-02.
Without the snippet, when you export to PDF
With this snippet (click to zoom)
Snippet
@media print {
  h1, h2, h3, h4, h5, h6, p, ul, li, ol {
    font-size: initial;
    font-weight: initial;
    font-family: initial;
    color: initial !important;
    background: none !important;
    outline: none !important;
    border: none !important;
    text-shadow: none !important;
  th, td {
    font-size: initial;
    border: 1px solid darkgray !important;
  a {
    font-size: initial;
    color: blue !important;
    text-decoration: underline !important;
  a[aria-label]::after {
    display: inline !important;
    content: " (" attr(aria-label) ")" !important;
    color: #666 !important;
    vertical-align: super !important;
    font-size: 70% !important;
    text-decoration: none !important;
  pre,
  code span,
  code {
    color: black !important;
    background-color: white !important;
  code {
    padding: 0 0.2em !important;
    line-height: initial !important;
    border-radius: 0 !important;
  pre {
    margin: 1em 0px !important;
    padding: 0.5em !important;
  pre > code {
    font-size: 12px !important;
    padding: 0 !important;
  pre > code .token.em { font-style: italic !important; }
  pre > code .token.link { text-decoration: underline !important; }
  pre > code .token.strikethrough { text-decoration: line-through !important; }
  pre > code .token { color: #000 !important; }
  pre > code .token.keyword { color: #708 !important; }
  pre > code .token.number { color: #164 !important; }
  pre > code .token.variable {  }
  pre > code .token.punctuation {  }
  pre > code .token.property {  }
  pre > code .token.operator {  }
  pre > code .token.def { color: #00f !important; }
  pre > code .token.atom { color: #219 !important; }
  pre > code .token.variable-2 { color: #05a !important; }
  pre > code .token.type { color: #085 !important; }
  pre > code .token.comment { color: #a50 !important; }
  pre > code .token.string { color: #a11 !important; }
  pre > code .token.string-2 { color: #f50 !important; }
  pre > code .token.meta { color: #555 !important; }
  pre > code .token.qualifier { color: #555 !important; }
  pre > code .token.builtin { color: #30a !important; }
  pre > code .token.bracket { color: #997 !important; }
  pre > code .token.tag { color: #170 !important; }
  pre > code .token.attribute { color: #00c !important; }
  pre > code .token.hr { color: #999 !important; }
  pre > code .token.link { color: #00c !important; }
Markdown code used in the example: Obsidian markdown print example · GitHub
Thanks so much for the CSS.
How can I extend this to be able to generate a table of contents for markdown document headers?
This can’t be done with CSS snippets, but you could generate the ToC before printing with an additional plugin, maybe with this one GitHub - hipstersmoothie/obsidian-plugin-toc: Create a tables of contents for a note. ?
Thank you for your answer!!
I had already tried, but unfortunately the table of contents that works in obsidian does not work when exported to pdf and entries look like this:
What am I doing wrong?
What’s the markdown code for that bullet point?
