Pasting from clipboard is not working in vim insert mode
  1. Enable vim mode
  2. Copy some text to the clipboard from outside of Obsidian
  3. Open or create a note
  4. Go to insert mode using i
  5. Try to paste the text using <C-r>+ or <C-r>*
Y
The text should be pasted from the clipboard.
It does nothing.
Obsidian version: v1.7.4
Installer version: v1.7.4
Operating system: Windows 11 Pro 10.0.22631
  1. If the text is copied inside Obsidian, then it shows up in insert mode.
  2. In normal mode, "+p or "*p does work as expected regardless of where the text is copied from.
I have encountered this too.
  1. Does it happen in the sandbox vault?
  2. Does it happen in source mode?
  3. Does it happen here https://raw.githack.com/replit/codemirror-vim/master/dev/web-demo.html ?
Yes, in all counts.
