Pasting file with Ctrl-V does not work after upgrading to v0.13.31
Copy a file in a file explorer (with Ctrl+C).
Go to Obsidian and paste the copied file with Ctrl-V.
The file is copied to the Vault and a link to it is created in the note.
Nothing happens.
  • Debug info:
    Obsidian version: v0.13.31
    Installer version: v0.12.5
    Operating system: Windows 10 Pro 10.0.19044
    Legacy editor: off
    Community theme: Comfort color dark
    Safe mode: on
The file pasting operation worked on v0.13.23. After upgrading to v0.13.31, the problem started happening.
Try updating the installer by doing a full download and clean installation:
That’s a requirement for any build of Obsidian from v0.13.30 or above.
https://forum.obsidian.md/t/obsidian-release-v0-13-30/33594
Angel
Thank you for your suggestion !!
Yes, downloading the installer fixed the problem like a charm !
