Pasted Images not rendering in correct order
I’ve been an avid defender of this Markdown app for years. However, lately, this has changed as the most recent changes in updates have broken my workflow.
I have thousand of notes created over the years and I use lots of images for my user guides.
I normally create a hierarchy folder tree which contains a specific folder called “resources”. This folder is the one I use per parent folder to save the images I need for each note I create.
I’ve noticed that no matter what I do, whether it is using a local copy of my vault, a third party syncing method and now the Obsidian Sync paid feature, the images pasted are not rendered in the correct order or there are completely different images in my notes which were not supposed to be there in the first place.
This happens regardless of creating creating a new note, or seeing my older notes. The pasted images (most of which are saved in the “resources” folders per parent topic), are not showing the way they should.
I made sure these images are saved to the “resources” folder of the parent folder for the topic in question, then close Obsidian, and shutdown my computer.
When I launched Obsidian app again later in the day or the next day, and take a look at the notes, the images are simply not rendering in the right place within the note body, or there are simply inaccurate images that do not belong to a particular note.
This is so frustrating as I have to manually look for the right images and then use them again to replace the wrong ones per note. Needless to say, this is quite upsetting as I lose valuable time.
  1. I create a new note, create my user guide step by step including images (some of them pasted from clipboard after capturing screenshots). I placed the images into a new “resources” folder I create per topic (parent folder).
  2. I wait for the syncing process to finish. Everything looks good, so I close Obsidian app or shutdown my computer if no longer needed.
  3. The next day or the very same day when I see the note I created, I notice that the images are not the ones I pasted when I created the guide. In some cases, the images are not even in the right sequence per steps in my guide.
Please note that this is also happening to my existing notes from years ago.
Did you follow the troubleshooting guide? Yes.
There are no custom CSS themes or plugins, other than the ones strictly required to enhance my productivity creating notes.
I do have multiple third party plugins but I always keep them up to date.
I expect to see my notes rendering the correct images when I create my notes and paste images. This should be the outcome all the time even after close Obsidian or restart the computer.
I keep seeing images missing or not placed in the right order per steps.
Obsidian version: v1.8.9
Installer version: v1.8.9
Operating system: #1 SMP PREEMPT_DYNAMIC Thu, 13 Mar 2025 18:12:00 +0000 6.13.7-arch1-1
Catalyst license: none
Live preview: off
Community theme: Neovim v0.4.0
Plugins installed: 61
Plugins enabled: 61
1: Advanced Canvas v4.0.1
2: Advanced Tables v0.22.1
3: Advanced URI v1.44.3
4: Annotator v0.2.11
5: Auto Link Title v1.5.5
6: Automatic Table Of Contents v1.6.1
7: Bible Reference v2024.12.09
8: Charts v3.9.0
9: Charts View v1.2.7
10: Copy document as HTML v0.8.1
11: Dataview v0.5.67
12: Editing Toolbar v3.1.1
13: Editor Width Slider v1.0.5
14: Emoji Toolbar v0.4.1
15: Epub Importer v0.6.6
16: ePub Reader v1.0.2
17: Excalidraw v2.9.2
18: Excel v1.3.24
19: Excel to Markdown Table v0.4.0
20: File Explorer Note Count v1.2.3
21: Footnote Shortcut v0.1.3
22: HTML Reader v1.0.12
23: HTML Tags Autocomplete v0.0.7
24: Image Caption v0.0.15.alpha
25: Image Captions v1.1.5
26: Image Converter v1.3.10
27: Image Helper v1.0.1
28: Image in Editor v2.2.6
29: Image to text OCR v1.0.3
30: Image Toolkit v1.4.2
31: Image2LaTEX v1.1.2
32: Importer v1.6.19
33: Kanban v2.0.51
34: Latex Suite v1.9.8
35: Link Converter v0.1.6
36: Longform v2.0.7
37: Media Extended v3.2.6
38: Mermaid Tools v1.2.0
39: Mousewheel Image zoom v1.0.22
40: MSG Handler v0.0.6
41: Multi-Column Markdown v0.9.1
42: Natural Language Dates v0.6.2
43: Omnisearch v1.26.1
44: Reminder v1.1.18
45: Recent Files v1.7.4
46: PlantUML v1.8.0
47: Table Generator v1.4.1
48: Task Genius v4.0.1
49: Templater v2.10.0
50: Tasks v7.18.2
51: Text Extractor v0.5.2
52: Text Format v3.1.0
53: Time Things v1.3.0
54: Tracker v1.15.1
55: Smart Typography v1.0.18
56: Sheets Extended v1.2.10
57: Hover Editor v0.11.26
58: markdown export v1.0.24
59: Iconize v2.14.7
60: Style Settings v1.0.9
61: Big Calendar v1.2.0
Moved to Help for now.
You need to follow the full debug steps when submitting bug reports. Thanks.
Issue cannot be reproduced in Sandbox as the changes are lost one Sandbox is closed. The main goal to confirm if this issue reproduces or not is to be able to close the app and then reopen to see if the images lost their proper position within the notes or not.
Please suggest another method to test and confirm.
Thanks!
Create a new vault and show the issue happen ing there.
I ended up moving my Vault to Joplin. I won’t have to deal with this issue with that app even with a third party syncing method like Dropbox. Too bad for Obsidian but it’s sad seeing such a great app not handling well a syncing problem where it keeps loading images where they should not be.
I haven’t encountered similar problems here before.
If possible, it is recommended to create an empty warehouse and follow your steps to see if such problems will occur again. This can avoid many problems caused by plugin conflicts.
Because your plugin library seems to have many plugins related to images, no one knows if it may be caused by these plugins:
