Paste from Perplexity is altering fenced code blocks
Ask a question in Perplexity that outputs a fenced code block.
At the bottom click on the copy icon to copy the results to the clipboard.
Paste the results to a new note in Obsidian.
The code block will not be reproduced faithfully in the raw markdown.
With the clipboard contents still in place paste the same information into a blank document in
Notepad++ or VSCode. The raw markdown is what you would expect. Example data below.
Now “select all” the data that you just pasted into Notepad++ and copy it to the clipboard.
Now paste the contents of the clipboard to a new note in Obsidian the code block will be formatted as you would expect.
Exact same behavior with restricted mode enabled.
The raw markdown for the paste of the fenced code should look like this:
  ```python
  import frontmatter
  # Create content for the markdown file
  content = "This is the main content of my markdown file."
  # Create a dictionary with frontmatter metadata
  post = {}
  post["title"] = "My Example Markdown"
  post["date"] = "2025-03-19"
  post["tags"] = ["python", "markdown", "tutorial"]
  post["author"] = "Python Developer"
  # Create a Post object with content and metadata
  post_obj = frontmatter.Post(content, **post)
  # Write the post to a file
  with open('example.md', 'w') as f:
      f.write(frontmatter.dumps(post_obj))
### Actual result
<!-- Instead of the expected result, what happened? -->
python
import frontmatter # Create content for the markdown file content = "This is the main content of my markdown file." # Create a dictionary with frontmatter metadata post = {} post["title"] = "My Example Markdown" post["date"] = "2025-03-19" post["tags"] = ["python", "markdown", "tutorial"] post["author"] = "Python Developer" # Create a Post object with content and metadata post_obj = frontmatter.Post(content, **post) # Write the post to a file with open('example.md', 'w') as f: f.write(frontmatter.dumps(post_obj))
### Environment
<!-- Paste your debug info below, which can be accessed by Command Palette (Ctrl/Cmd-P on Desktop, Swipe down from the top on mobile) enter "Show debug info", and click "Copy to clipboard". -->
	Obsidian version: v1.8.9
	Installer version: v1.8.7
	Catalyst license: insider
	Insider build toggle: on
	Base theme: light
	Community theme: Prism v3.6.0
	Snippets enabled: 3
### Additional information
![ksnip_20250319-165546|690x254](upload://hMmTU6qoef0yO2ioU6HAOAIHRoX.png)
Anything else you think would help our investigation, like a screenshot or a log file?
You can drag and drop screenshots to this box.
For large amount of text, try putting them into something like Pastebin.
For videos, upload them somewhere and drop a link here.
I am not sure what format(s) perplexity puts on the clipboard
Have you tried pasting as plain text (ctrl-shift-v)?!?
This does indeed solve the problem. Not really worth time to figure out when the windows clipboard is “active” vs passive.
Thanks.
