When I copy and paste code blocks from chat gpt, they are not placed properly.
It appears in plain text as seen in the image below. It appears properly in note applications such as Notion or anytype.
Is there any way to fix this?
No idea what this is but do you know about ‘SHIFT+CTRL+V’?
When I use ‘SHIFT+CTRL+V’ it is pasted as plain text and there is no code block as below and when I use ‘CTRL + V’ it is pasted like the first photo but I want to see it inside the code block and properly aligned as in the bottom photo (photo taken from another application)
wrap your pasted content in
to format it as code in markdown.
It seems like you don’t know much markdown nor c++, if you’re just starting out your programming journey I’d suggest you to learn rust, since it has better error messages. You don’t want 1000 errors becuase a typo while you’re leaning your first language.
