The editor currently does not provide any special handling for hashtags inside parenthesis. Unfortunately, this is a pretty common use case, as evidenced by multiple bug reports having been posted - but pushed to the graveyard because it is “by design”:
For instance, I could make a sentence on some core concepts and then list hashtags at the end (#CommonUsage, #Hashtags101, #DesperateForNormalLookingText). But in the current parsing routines for Hashtags, the #CommonUsage tag will not be parsed.
I suspect there may be a few other punctuation marks that would be good to handle in the parsing routine as well, e.g. ~ or ". Also some formatting marks would be helpful - like #HashTag should be valid.
The easiest work around is to add a space after the parenthesis, but this is not proper english grammar. I’ve not found any other workaround to date.
Thank you again!
