Hi y’all!
I’ve attempted to recreate a PARA + GTD setup as found in this medium article. Unfortunately, the queries he provides do not seem to work for me.
I have the Tasks and the Dataview plugins. In addition, I’ve setup Tasks plugin and also made sure I have the Tags plugin enabled.
The only difference between my setup and his is the names of my PARA folders. I’m considering each part of PARA as a map of content and therefore append “MOC” to the end of it. In addition, I’m prefixing the folders with a number as makes sense for PARA.
This makes my final notes:
1 Projects MOC
2 Areas MOC
3 Resources MOC
4 Archives MOC
All of this being said, I think I have updated the query he has provided correctly. I believe that the only thing I need to do is update the outgoing file from “Projects” to “1 Projects MOC”. This is what I’ve come up with:
let projects = dv.pages('outgoing([[1 Projects MOC]])')
let rows = projects.flatMap(
page => page.file.tasks
.filter(t => !t.completed && t.text.includes('#next'))
.map(task => [page.file.link, task.text.replace('#next', '')]
dv.table(['Project', 'Next'], rows)
After attempting to run this (ctrl+e), I get the following error:
Dataview: Error:
-- PARSING FAILED --------------------------------------------------
> 1 | let projects = dv.pages('outgoing([[1 Projects MOC]])')
2 | let rows = projects.flatMap(
3 | page => page.file.tasks
Expected:
TABLE or LIST or TASK or CALENDAR
So I am thinking I should put “TABLE” at the beginning of the query. However, if I do that, I get the following error:
Dataview: Error:
1 | TABLE
> 2 | let projects = dv.pages('outgoing([[1 Projects MOC]])')
3 | let rows = projects.flatMap(
4 | page => page.file.tasks
Expected one of the following:
'*' or '/' or '%', '+' or '-', ',', '>=' or '<=' or '!=' or '=' or '>' or '<', 'and' or 'or', /AS/i, /FROM/i, EOF, FLATTEN <value> [AS <name>], GROUP BY <value> [AS <name>], LIMIT <value>, SORT field [ASC/DESC], WHERE <expression>
Not sure where to go from here. I hope I’m being clear. Please help
I’d like to have all 4 queries he has but can’t even get past the first one. I’d like some help troubleshooting the aforementioned errors.
