Paper Texture Background Style
Effect
Add a gradient paper texture background to the editing area, as shown:
Dark background:
Style File
Using CSS:
/* Paper texture image */
:root {
    --paper-texture: url(data:image/svg+xml;base64,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)
/* Empty tab */
.view-content .empty-state-container,
/* Reading view */
.markdown-preview-view.markdown-rendered,
/* Editor in edit view */
.cm-editor {
    --editor-texture: var(--paper-texture);
    --c:
        color-mix(in srgb, var(--background-primary), transparent calc(0%));
 	--c-deep:
        color-mix(in srgb, var(--background-primary), transparent calc(35%));
    background-color: var(--background-primary) !important;
    background-image:
        linear-gradient(to right, var(--c), var(--c-deep) 30%,
            var(--c-deep) 70%, var(--c) 100%),
            var(--editor-texture) !important;
    background-blend-mode: normal, multiply;
/* Adjustments for dark theme */
.theme-dark {
    .cm-editor {
        --c-deep:
            color-mix(in srgb, var(--background-primary), transparent calc(10%));
        background-blend-mode: normal, color-dodge;
Click to download: Moy Paper Texture Background
Attribution
  1. The method of adding background texture comes from the theme Fancy-a-story
  2. The background texture pattern comes from the theme Retronotes
  3. Heading font: 匯文明朝體
  4. Screenshot theme: Origami
For code novices like myself: I modified a line of this CSS code. The goal is to apply this snippet only if the value “etude” is one of the values ​​in the “cssclasses” property. You can, of course, choose a value other than “etude” as long as you make sure to modify the “:root” declaration accordingly. I’m not an expert in CSS, but this seems to work.
Here’s the modified line:
:root  .etude {
