Pandoc Plugin does not export equations to Latex
I am trying, via the pandoc community plugin, to export some notes (to latex) which contain equations. The notes view correctly with the equations present. The equations surrounded by $$ are present in the .md notes file.
The export produces a latex file but each equation is shown as a pair of curly brackets ie {}.
I’ve looked through the forum in the Help and Bug sections and cannot find similar problems.
I’ve tried using pandoc directly. The equations are present but not enclosed with $$.
Any guidance or advice appreciated.
Thanks.
I have exactly the same issue. Does anyone have a solution ?
