Hello, all. I am trying to install Pandoc in order to batch export notes to PDF. Currently, Pandoc is installed and I believe it has the proper path for my computer. While the pandoc commands are showing up in one area: pinned commands, they are not showing up anywhere else. Even when I do pin a command, it does not show up in the main commands section.
I’m sure I am just missing something. Coding or anything close is definitely not my strong suit. I would be grateful for any support! TY!
–Amber
Hi Amber,
Did you have an editor active when trying to find the Pandoc plugin commands in the command palette? That’s required. Looks like you had graph view active at the time.
Thank you, @Feralflora ! I appreciate the quick and insightful response. I would have been majorly lost without your assistance!
–Amber
You’re welcome, glad I could help! Btw, if you run into other issues 1) don’t hesitate reaching out again and 2) know that the Pandoc plugin has some issues since it hasn’t been updated in more than two years, so you might want to try the other plugin for Pandoc called Enhancing export if things aren’t working as expected.
