Painting myself into a corner with Dataview for TASKS?
I might be on the right track, but could I trouble you for a little reality check? I have a large number of tasks sitting in Word. I would like to try managing them in Obsidian. I’m making progress, learning that I must use the Refactor plugin because just dumping them in causes them to be one giant note that Dataview can’t comprehend. I also have to use the QuickAdd plugin to be able to quickly capture a task, but make sure it goes into the Tasks folder. Since there could be a thousand tasks, they should be in their own folder. Are there folks happily bopping along with this kind of arrangement, OR am I setting myself up for a precarious situation that will require a lot of fiddling, turning task management into its own hobby instead of an efficient tool? OR, am I missing any alternative strategies that could be a lot better? By the way, I’m using Dataview because of the way I manage tasks, it looks like it will be a lot better than the Tasks plugin. Any brainstorming or opinions are welcome. Thanks for any comments.
Will
What you’re describing - one note per task with QuickAdd + Dataview - is actually a pretty common pattern and it works well once set up. The front-loaded complexity is real but mostly one-time. For a thousand tasks, I’d suggest keeping the metadata simple at first (status:: and due:: to start) and only adding fields you’ll actually query. The fiddling phase is mostly the template setup; day-to-day it gets pretty smooth.
Each task is a separate file? How do you name the files? And why not use the Tasks plugin?
Based on posts and what I want to do, I have a multi-dimensional (for want of a better term) method of working from my tasks list that it appears would be better facilitated by Dataview than Tasks. As for the many files: the method for keeping all the tasks in a single note can result in things getting bogged down. The name of each file could be the task, for example: “Cancel Microsoft 365.” But, as a rank beginner, I need to keep a very open mind about my plans.
one task per .md sounds perfect for TaskNotes.
I am very curious to hear about how you end up going with this. I am just starting out with tasks in Obsidian, and the only thing I am confident about so far is that I much prefer Dataview queries to Tasks queries. Something about the Tasks query results seemed aesthetically displeasing, and my patience ran out before my CSS skills could find a fix. Dataview results, on the other hand, just click for me. Yes, I intend my puns, and I much prefer the clickable results from Dataview compared to Tasks’ ugly link in long mode and the ugly link icon in short mode.
But I am taking advantage of Tasks different task icons and statuses. My Dataview queries are able to search for status = “I” to separate out the ‘ideas’ from regular tasks.
I am also very curious to hear about how Dataview crashes with a thousand tasks in one file. I am rebuilding my LogSeq tasks queue at the moment and expect to have hundreds (though probably not a thousand) tasks across dozens of pages. I don’t know if more files will make it better or worse, yet so far it is going swimmingly.
To summarise, I would just like to hear about a real world situation like yours, what worked and what didn’t, instead of just another “I read Getting Things Done and it says to do this” kind of post.
Best of luck.
