Pagination for tables
Really long tables can be cumbersome to scroll through if you want to get to the text below it.
A setting for pagination of tables could help with this.
I have no clue if this is remotely possible with the new table feature you’re building, but if it is then this would be a really great QoL feature.
As a workaround you can put a heading above the table or the text below it and move to it via the Outline.
