Create a knowledge graph of Questions & their underlying concept. This is how it looks:
As seen in the above graph, Some of the nodes in blue are questions. The nodes in peach are tags. Nodes in grey are orphan references. They will turn blue when I create a page for them (eg: ‘K-Heap’).
Now, I desire to create a different colour schema for questions and concepts. This I have realised I can do by creating tags. The limitation on tags is that I cant have a page that talks about what the concept is and I also cant link a tag to another tag.
Is there a way wherein I can create pages for tags and link it to other sub-tags?
My requirement is to have a hierarchy of connections such that each question links to a concept which in turn links to a sub concept. Each of the entities (question, concept, sub concept) should be identified via different colours and filtering.
How do I achieve this?
I think tags might add complexity here that you don’t need yet.
What happens if instead of tags, everything was a link to page? Tags would be pages. Sub tags would be pages. Questions would be pages. Answers would be pages.
Maybe use tags to indicate #question, #concept, and even #sub-concept.
Then everything has the page it needs, and you can use tags to color nodes on the graph.
@austin That you for the solution, that works for me - ingenious & simple!
