Page breaks for PDF (again)
I stumbled upon this question while checking out the forum’s most viewed posts.
When I export to PDF natively via the Obsidian menu. I would like to have the pages breaking at the correct point of the content. Not during a paragraph or item.
Insert a char for page breaks that the export to pdf feature adheres to.
I came up with a solution that might be useful, but unfortunately the topic was closed. So I open this new one.
The idea is to use the --- markdown syntax (used to insert a horizontal rule), for this purpose.
You can add to .obsidian/snippets the following snippet in a file called for example hrule-is-page-break.css:
@media print {
  hr {
    visibility: hidden;
    page-break-before: always;
If you activate this snippet in Obsdian Settings → Appearance, then the --- is transformed into a page break when converting to pdf (it remains visible as a horizontal rule in Obsidian preview).
If you have other notes with horizontal rules and you want to print those “normally”, deactivate the snippet before exporting to pdf.
You can add
<div style="break-after: page;"></div>
for page breaks anywhere.
There are also css options for breaking before/after any h1, h2, etc., heading.
This is a great addition to our export options. Thanks!
Great two solutions although you don’t know beforehand how your content is going to be divided across different pages. I would instantly go and transfer my markdown documents to LaTeX or ODT[1] if printing/document export is considered. In some light use cases you can also import markdown to Google Docs[2]. For most users Google Docs could be ideal solution to do relatively fast printing on the fly.
  1. https://github.com/mokeyish/obsidian-enhancing-export ↩︎
  2. https://www.howtogeek.com/google-docs-markdown-import-export/ ↩︎
