Oxidation number of elements does not render
Paste this into a note:
\ce{2\ox{0,Na} + \ox{0,Cl2} -> 2\ox{+1,Na}\ox{-1,Cl}}
Oxidation numbers should be shown with an upper index.
The oxidation number won’t be shown properly, there will be \ox in red.
Operating system: android 15 (Xiaomi 2410CRP4CG)
Webview version: 144.0.7559.109
Obsidian version: 1.11.7 (287)
API version: v1.11.7
This might be because the LaTeX mhchem package is not fully supported. Though \ce works just fine. I have no idea about the scale of this problem (which other LaTeX formulas don’t work). I just stumbled across this when taking notes.
Looks the same here: https://www.mathjax.org/#demo for me.
Obsidian only supports MathJax, by default, as far as I know. Have a look here:
I did some more digging and read the manual:
The oxidation state should actually be written like this:
\ce{Fe^{II}Fe^{III}2O4}
Which works is Obsidian.
I got confused. The \ox command is provided by a different package named chemmacros.
