$\overrightarrow{\rm AB}$ renders badly
Before opening a new bug report, please search the forum for duplicates and follow the Troubleshooting Guide.
  • We only consider bugs that are reproducible in the sandbox vault or a vault with no third-party plugins/no css snippets/default theme.
  • For Linux, we only accept bug reports that are reproducible with our Appimage package under Gnome or KDE.
  • Developer issues with the API should go here
$\overline{\rm AB}$ looks good!
$\overrightarrow{\rm AB}$ looks bad!
You bet I did!
I expected to see a well rendered arrow stem, just as \overline renders.
A poorly rendered arrow stem, looking as if two different stems were concatenated. No change in rendering between reading and preview modes.
Obsidian version: v1.3.7
Installer version: v1.3.5
Catalyst license: insider
Legacy editor: off
Plugins installed: 0
Plugins enabled: 0
I believe that this is an issue that only happens on Windows. Zooming in or out can help or a different font size. You could try if you have the same results here:
