Enter either $ or $$ modes and use the \overline{} command
A line that spans the given text
Nothing appears changed about the text
  • Operating system: Linux
  • Obsidian version: v0.10.11
I have tried to disabling and enabling plugins and CSS snippets but to no avail.
post a screenshot
Before (Editing)
Before
After (Display)
After
have you tried zooming in?
Thank you, it seems zooming it fixes the problem, but that brings the problem of having everything way too large. Is there a way to fix this without resorting to zooming in?
you can try to increase the size of math formulae with some css. Side note: what is you screen resolution?
My screen resolution is 1920x1080. Also what would be the css class for math symbols?
mjx-math {
font-size: 120%;
Thank you for your help. Will this always be the case for this issue, or is there a possibility the rendering will not be encumbered by this problem in the future.
This is a mathjax problem with chtml output. The fix is either using svg output or bigger default font.
I thought MathJax had some keywords for that too.
Try $\huge \iiint$and $\Huge \iiint$for example.
Not sure that is the answer to the question but perhaps it can trigger some other thoughts…
