video in MKV format you can watch to see the bug live using the Obsidian Sandbox with version 1.5.3:
Step 1: Open Obsidian Sandbox
Step 2: Create a new note
Step 3: Add 350+ Heading 3 (###) to the note (make sure each heading has it’s own carriage return)
Step 4: Open the Outline pane for the newly created note on the right hand side.
Step 5: Scroll to the bottom of the Outline pane for the newly created note
Step 6: Scroll to the bottom of the newly created note
Step 7: Add a new Heading 3 (###) and start typing your new heading title…
Step 8: Watch how the bug in the Outline pane automatically scrolls up and around.
Step 9: The newly created Heading 3 (###) is no longer showing at the bottom of the Outline pane where the newly created Heading 3 (###) was just added.
Step 10: Try and update the Heading 3 (###) you just added or even add another Heading 3 (###) below and the Outline pane scrolls up and around again while you are typing… very disorientating.
Step 11: The updated or newly added Heading 3 (###) will no longer be in view in the Outline pane.
Yes the steps above are reproduced in the sandbox vault with no community plugins enabled.
When I type a new or are modifying an existing Heading 3 (###); the expected behaviour would be for the Outline pane to stay at the same position with the new or modified Heading 3 (###) in view within the Outline pane.
When I type a new or are modifying an existing Heading 3 (###); the actual behaviour is the Outline pane to scrolls around and no longer has the newly added or modified Heading 3 (###) in view anymore within the Outline pane.
Obsidian version: v1.5.3
Installer version: v1.5.3
Operating system: Windows 10 Pro 10.0.22000
There’s a “Default Expand Level” function that doesn’t work (the outline is always expanded all the way whenever I open any note, and when I fold the outline everything will just auto-expand when I start typing in the note)
If you can show me how to fix my issue without needing to use Quiet Outline that would be a godsend, I figured out I just didn’t have Quiet Outline on lol. Now I do but I like how the vanilla Obsidian outline looks much better
