Outline or Navigation, or Pins for Canvas
A way to see the card titles or card groups in a table contents format or links format (that we can re-arrange). It’s hard to navigate a canvas or gain an overview of where is where.
I imagine a way to get a link to the card groups/cards would be a good start. That way we can make an outline of these nodes, and upon clicking on these links we can navigate to that part of the canvas.
I try to make card groups as much as possible so that things don’t get lost. I also try to make a note about the topics covered by a canvas just to be sure I can find them later.
I’m not sure if related or if I’m using a plugin for it atm, but I remember there was a time that even just searching text in a canvas is difficult. This feature is crucial.
I created a plugin which displays a pane with clickable links to current Canvas cards. Those links are listed alphabetically according to first line context of each card. Possible HTML tags etc. are stripped from that comparison. Is there already some similar plugin ?
