It would be a nice QOL improvement if the outgoing links plugin would not suggests words in Hashtags, because links [[]]
in hashtags are not allowed anyways. This would declutter the interface and prevent braking tags.
BTW the same applies for internal Links [[]]
, external MD links inside the []
and ()
part, and codeblocks.
Hi, as you can see in my screenshot I have a note called Elli
and if I have a tag that contains the file name as part of the tags, in my example #Elli/Gesundheit...
the outgoing link plugin will suggests Elli
as a link. Clicking on it would result in #[[Elli]]/Gesundheit...
and this I consider as broken. It won’t act as a tag anymore and should not be suggested. The same applies for something like [Elli](https://some.extenal.link)
or [[Elli is the name of my dog]]
