- Open Obsidian in Restricted mode (Settings → Community plugins → Turn on Restricted mode).
- Disable
Settings → Editor → Smart indent lists. - Copy this exact text:
## Stage One 1. Abc 2. aBc 3. abC ## Stage Two There is text between the lists. The lists are logically independent. 1. Xyz 2. xYz 3. xyZ - Paste into Obsidian using
Ctrl/Cmd+Shift+V(plain text paste).
Note: Steps 1 (Restricted mode), 2 (disabling Smart indent lists), and 4 (plain-text paste) are not inherently required to trigger the issue. They are included to conclusively demonstrate that this behavior:
- Might originate from core editor logic
- Is unrelated to plugins/paste formats
Y
- Reproduced in sandbox vault (new vault created via restricted mode)
- Default theme, no CSS snippets, no plugins
- Tested on both Windows and macOS versions
Source code should preserve original numbering:
## Stage One
1. Abc
2. aBc
3. abC
## Stage Two
1. Xyz <!-- Should remain 1. -->
2. xYz
3. xyZ
Obsidian modifies the source code:
## Stage One
1. Abc
2. aBc
3. abC
## Stage Two
4. Xyz <!-- Source code is altered to 4. -->
5. xYz
6. xyZ
Obsidian Version: v1.8.4
Installer version: v1.7.4
Operating system: Windows 10 Pro 23H2 (also reproduced on macOS Sequoia)
Key Issue Clarification
This is not a rendering issue - Obsidian physically modifies the pasted source code text.
Workaround impact
Users must manually edit numbering or insert <!-- --> comments to block auto-formatting, which disrupts workflow.
