record an audio file it will get added to the note. But after that if you click on 3 dot menu next to audio file embedded in the note the menu is rendered behind the UI.
The audio menu should render fully on top the audio file UI element
The options menu for that audio file is behind the element and not visible to the user
- Operating system: Mac OS 11.2.3
- Obsidian version: v0.11.13
