Option to keep headings collapsed when applying a template
I use a template (auto applied with Templater) for my daily notes that has several categories, each of them is a seperate heading. However, I don’t write under each category every day. I collapse headings in the template, however they still all show up expanded in my daily note. This bugs me, I have to collapse them all manually.
I would like to see an option to keep collapsed headings in a template collapsed in the note it is applied to. I know this can be done with callouts, but I have style settings for my callouts that I use in other circumstances, I don’t want my daily note to look like that.
Might or might not help in the meantime:
Obsidian has a command to Fold all headings and lists that you can have Templater automatically run after applying the rest of the template. Or assign a hotkey to the command and manually press it.
It would fold any lists in your note too though. Plugins offer finer control over what gets folded.
Thanks. I really need some folded and others not. I will see if I can solve this with a plugin in the mean time.
