Click on the “Help” icon (question mark in a circle), located above the “Settings” icon (gear).
OR
Click on “Open Vault” & choose “Open help vault”.
I expected that any settings/plugins that I customized to persist into the “Help” instance of Obsidian.
It appears that accessing “Help” opens a new instance of Obsidian with the default settings & plugins.
I’m not completely sure they’re the default ones, but they’re drastically different that how I had mine set & assume they’re the default.
It’s not a huge issue as once all instances of Obsidian are closed and it is reopened the user’s custom settings do persist. It is just initially confusing & misleading.
- Operating system: Windows 10
