We strongly recommend you to search the forum with possible keywords before making a new feature request. If your request is very similar to an existing one, consider liking it and/or making a comment rather than making a new one. Once you’ve searched and determined that this is a new request, delete this line.
I want to easily open Obsidian links from obsidian using ctrl+click.
I expect to use this feature to jump from one vault to another.
Be able to open obsidian links in the same way we open http URLs
To copy the obsidian URL and paste it in the browser, this opens the corresponding element
it already works. put it in markdown link format
[link](obsidian://xxx)
You are right it works!.
This is a super quick way to jump from one vault to another
