I start Obsidian, open any vault, and try to open a file or a folder in the system explorer via context menu: my VSCode pops up instead of expected SpaceFM for folders for example:
root@porteus:~# xdg-mime query default inode/directory
spacefm.desktop
root@porteus:~# /I/Obsidian.AppImage --no-sandbox
Setting $HOME to /I/Obsidian.AppImage.home
Setting $XDG_CONFIG_HOME to /I/Obsidian.AppImage.config
2025-04-14 12:15:37 Loading main app package /tmp/.mount_Obsidi4WLtOM/resources/obsidian.asar
[5230:0415/001538.202733:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.DBus.StartServiceByName: object_path= /org/freedesktop/DBus: org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.portal.Desktop exited with status 127
MESA-INTEL: warning: Haswell Vulkan support is incomplete
2025-04-14 12:15:38 Checking for update using Github
libva error: /usr/lib64/dri/iHD_drv_video.so init failed
2025-04-14 12:15:38 Success.
2025-04-14 12:15:38 Latest version is 1.8.9
2025-04-14 12:15:38 App is up to date.
[5230:0415/001541.338416:ERROR:atom_cache.cc(229)] Add WM_CHANGE_STATE to kAtomsToCache
[5230:0415/001635.935695:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.portal.OpenURI.OpenDirectory: object_path= /org/freedesktop/portal/desktop: org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.portal.Desktop exited with status 127
[5230:0415/001635.935710:ERROR:platform_util_linux.cc(242)] Error calling OpenDirectory
[5504:0415/001636.496723:ERROR:object_proxy.cc(576)] Failed to call method: org.freedesktop.DBus.StartServiceByName: object_path= /org/freedesktop/DBus: org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.portal.Desktop exited with status 127
Warning: 'unity-launch' is not in the list of known options, but still passed to Electron/Chromium.
