Would be great we could define a hotkey in the hotkey menu for opening in the terminal the current vault or the folder that the current file is in–that is two different hotkeys. That feature could just open the folder in the systems default terminal to keep things simple.
Whenever you want to run a shell command on the current file, just press the hotkey and run it from your default shell, then close she terminal and go back or leave it open. I am thinking use cases such as wanting to run pandoc on a document to convert it but not necessarily wanting to automate that with a dedicated plugin.
