Only first paragraph / bullet point is folded when switching from Reader -> Editor
  1. Have more than one paragraph under a header.
  2. Switch to Reading View.
  3. Fold the header.
  4. Switch to Editing View.
Screen Recording 2025-02-03 004527
Yes, the above gif was demonstrated in sandbox mode.
Every paragraph under the header should be folded.
Only the first paragraph is folded.
	Obsidian version: v1.8.4
	Installer version: v1.8.4
	Operating system: Windows 11 Home 10.0.22635
	Catalyst license: none
This error occurs in both Live Preview and Source Mode.
Create a note with with at least 2 top level headers and at least 1 of them has a second level header in it.
# header 1
- list item 1
- list item 2
- list item 3
# header 2
- list item 1
- list item 2
- list item 3
## Header 2.1
- list item 1
- list item 2
- list item
Fold the second level header in source editing mode
look at another note
when you come back in the first list item is folded but the rest of the note is not
In reading mode the note appears properly folded.
Yes
Fold status should persist when going into and out of a note no matter whether it’s in reading or source mode. Folded headers should fold the entire contents.
Partial folding which was not the case in 1.7 versions
Installer version: v1.6.3
Operating system: Darwin Kernel Version 23.6.0: Fri Nov 15 15:11:49 PST 2024; root:xnu-10063.141.1.702.7~1/RELEASE_ARM64_T6020 23.6.0
Catalyst license: supporter
Live preview: off
Plugins installed: 1
Plugins enabled: 1
1: Kanban v1.5.3
thanks
I can confirm the existing of this issue in macos Obsidian Version 1.8.4 (Installer 1.8.4).
Same case; macOS 15.3 and Obsidian Version 1.8.4 (Installer 1.8.4)
will be fixed 1.8.6. No ETAs
