I’ve started using mobile more and I’m curious what is the quickest way to invoke plug-ins that require text selection?
When text is selected, there isn’t a way to bring up the command pallet right?
Using the new multi-colored highlighter “highlightr” plugin, are the only options put it on the toolbar above keyboard, or in the side pane? With the noterefactor plugin, I put it on the keyboard toolbar. I can see this getting overcrowded quick. I don’t think there are finger swipe “gestures” that you can bind to a plug-ins hotkey? I don’t use a keyboard on mobile.
