Open Obsidian. Use it for a while. At some point — I cannot precisely determine when it occurs or what causes it to occur — the top of the window will clip, and any of the controls at the top of the window will be only partially visible and unclickable.
I would not expect that this would ever happen.
- macOS 13.2
- Debug info:
Obsidian version: v1.1.16
Installer version: v0.14.15
Operating system: Darwin Kernel Version 22.3.0: Thu Jan 5 20:48:54 PST 2023; root:xnu-8792.81.2~2/RELEASE_ARM64_T6000 22.3.0
Catalyst license: supporter
Insider build toggle: on
Legacy editor: off
Community theme: Minimal v6.1.19
Snippets enabled: 12
Plugins installed: 129
Plugins enabled: 104
1: Admonition v9.2.1
2: Better Word Count v0.9.4
3: Buttons v0.4.19
4: Advanced Tables v0.18.1
5: Collapse All v1.5.3
6: Cycle through Panes v0.1.1
7: CSV Editor v0.0.1
8: Dataview v0.5.55
9: Emoji Toolbar v0.4.0
10: Excalidraw v1.8.19
11: Find orphaned files and broken links v1.8.0
12: Fullscreen mode plugin v0.1.2
13: Hotkeys++ v0.2.7
14: Icons v0.3.0
15: Imgur Plugin v2.2.1
16: Natural Language Dates v0.6.1
17: Recent Files v1.3.5
18: Show Current File Path v0.5.2
19: Sort & Permute lines v0.7.0
20: Tag Wrangler v0.5.6
21: Templater v1.16.0
22: Text Expander v1.1.1
23: Workbench v1.6.1
24: Note Refactor v1.7.1
25: File Explorer Note Count v1.2.0
26: Pluck v1.0.1
27: PDF Highlights v0.0.4
28: Timeline v1.1.0
29: Daily Activity v0.4.0
30: Underline v1.2.1
31: Plugin Changelogs v1.3.0
32: Hotkey Helper v0.3.15
33: Map View v3.0.1
34: Filename Heading Sync v1.8.0
35: Hotkeys for templates v1.4.3
36: Mind Map v1.1.0
37: Readwise Official v2.0.1
38: Media Extended v2.11.1
39: Number Headings v1.13.0
40: Rich Links v1.1.0
41: File path to URI v1.4.1
42: Jupyter plugin v0.8.5
43: Annotator v0.2.10
44: QuickAdd v0.12.0
45: Typewriter Scroll v0.2.2
46: Workspaces Plus v0.4.16
47: Editor Syntax Highlight v0.1.3
48: Outliner v4.2.1
49: Dynamic Table of Contents v0.0.27
50: Apply Patterns v2.1.2
51: Quote of the Day v1.0.1
52: Meld Calc v1.0.2
53: Hypothes.is v0.1.19
54: Reveal Active File Button v2.0.3
55: Highlightr v1.2.2
56: Dictionary v2.22.0
57: Zoom v1.1.1
58: PlantUML v1.6.6
59: Kroki v1.2.3
60: Regex Find/Replace v1.2.0
61: Icon Shortcodes v0.9.7
62: Kanban v1.5.2
63: Auto Note Mover v1.2.0
64: Settings Search v1.3.6
65: Tag & Word Cloud v1.3.2
66: File Info Panel v1.3
67: Creases v0.6.6
68: Lapel v0.1.0
69: Chat View v1.6.0
70: Better CodeBlock v1.0.8
71: Style Settings v1.0.3
72: Vantage - Advanced search builder v1.4.2
73: Omnisearch v1.13.0-beta.1
74: Obsidian Columns v1.4.0
75: Text Format v2.2.1
76: Minimal Theme Settings v6.3.1
77: Contextual Typography v2.2.4
78: Custom window title v0.3.5
79: Diagrams.net v1.0.4
80: Raindrop Highlights v0.0.14
81: Duplicate Line v1.2.0
82: Icon Folder v1.7.0
83: Linter v1.10.3
84: Remember cursor position v1.0.7
85: Obsidian asciimath v0.5.3
86: Plugin Update Tracker v1.4.5
87: Table of Contents v0.1.4
88: Commander v0.4.9
89: Book Search v0.5.9
90: Janitor v1.1.0
91: PodNotes v2.10.7
92: DB Folder v3.3.2
93: Spaced Repetition v1.10.0
94: Tasks v1.25.0
95: Mermaid Tools v0.1.1
96: Metadata Menu v0.4.21
97: Obsidian_to_Anki v3.4.1
98: Text Extractor v0.4.3
99: Things Logbook v0.1.16
100: Multi-Column Markdown v0.7.7
101: Supercharged Links v0.9.3
102: Calendar (Beta) v2.0.0-beta.2
103: Dynamic Highlights v0.3.1
104: Console Markdown Plugin v1.0.2
Reloading Obsidian restores the window without any clipping. However, if you continue to use the app, the clipping will return.
Here is a screenshot of the window after it has started clipping:
Here is a screenshot after reloading Obsidian:
Note that this behavior occurs whether the window is full screen or not. I do have Stage Manager enabled. I will investigate if disabling Stage Manager has any effect and report my findings.
