Hello!
There are lots of OCR plugins for Obsidian but all of them either require Internet connection or lag and crash on big files.
We have an example with Pandoc plugin: you download the pandoc.exe file, go to the plugin settings, specify the path and then get nice UI to interact with the Pandoc in obsidian, though all the work is done in pandoc.exe - 100% offline)
AI and so on is good, but it seems to be too much for just OCR a pdf book…
Suggest to create a Tesseract plugin of the same type. U download tesseract.exe, specify the path in obsidian and get the Fine-Reader like UI in Obsidian, allowing to OCR any type of files supported by Tesseract and get the text in a markdown note. - 100% offline! There also should be an option to download and update new languages from tesseract official sources to the plugin folder.
Thank you for consideration!
